Hi guys, my first test using Bucket mode.This is a personal project “Romantic”. This time I´m using Bucket mode and… I love it!! Thanks Michel Amorim for the tips.
I already like it.
Looks very promising, can’t wait to see more progress!
hi , good job … can you share what diffuse level and color you use ? you use post-prod? .. is really nice clean and sharp .. ani filter?
thanks … nice job …
Hi guys!!
pmcf1981: diffuse level = 1.0, RGB color 180, no post, bucket mode PT+PT. It´s all!!
what is this pmcf1981???
pmcf1981 is the name of the user.
Did you remove the image filter?
thnks crawlewis ![]()
one more question:
you only change to (PT + PT) and use default values ? or you change others things like MSI …
your white balance is perfect ..
thks ![]()
I only decrease Max ray depth to 8.
No Cyrus3v.
thks a lot crawlewis
iam gona try in my scene .. ![]()
cheers ![]()
Why the hell did you use max ray depth 8?
Can you post another render with no additional contrast for comparison?
I would use PT+HD in this case.
btw, does material override affect portals, too?
Thanks crawlewis. You render looks so sharp that I thought you removed the image filter to add some sharpness.
Interesting that you didn’t use any Photographic Exposure. Great result.
- Because 25 ray bounces in my opinion is to much for this scene. I don´t have use portals.
- With PT+PT I get more details. but I will try to HD Cache.
but I’m here to learn, and of course open to suggestions.
Where do I find this filter?
Under VFB Settings → Image Filter
Why? Do you even know what it does? What is the difference in comparison to default?
You should. It shouldn’t give you any visual difference but should speed up your rendering about 3-5 times. ![]()
This isn’t correct. Zero is just another exposure value, like 1 or -1 or any other number.
3-5 times speed up from portals alone? Are you sure?
So, what is the benefit of using Photographic Exposure? Using the Global Camera settings?
