A quick light setup through 2 windows, and getting the light to bounce round the room for a nice light solution ![]()
http://www.render-time.com/vray/room1.exe
nice!..thanks Natty.
I have a few friends and coworkers that wanna learn vray and i’m this will help out quite a bit!!..
paul.
Thanx natty, two nice tutorials, now just make 1 for exterior setup. ![]()
Thanks natty, downloading it now.
good job natty
really helpful
thx
zedz
Natty is super
can u post scene’s link , i don’t remember it
thx !
Thanks guy’s …i hope its of some help..
post the scene link later ![]()
Tuts
Thanks Natty,
What codec do I need installed to view the videos?
you dont … it runs itself .. it doesnt install anything ![]()
heres the file stripped down
Thanks for this. Did you turn down the “Global Lighting” Tinting parameter just so things would look better in the viewport? Why did you bother tweaking the Clr thresh and Nrm thresh values, when the Medium Irradience Map Preset overrides those settings?
Thanks,
yeah that was a mistake because i was going to render it with my own setting then i changed my mind during the vid … Panicked a bit..lolol ![]()
yeah and the global lighting is a good way to override the view port brightness … a good little trick.
May I ask you why did you change face/level coef. under Vray system rollout? Does it make any difference?
it seems that the default (2) is too high, so lowering it, it would make things fast but use more memory…at least that’s how I understand it.
paul.
yeah thats how i understand it aswell cocolas
Ahhh, thanks on that
I surely hope new VRay manual will explain all those things and spinners ![]()
Hey natty! Thanks for the tutorial. It’s always interesting to see how other people work with VRay. There’s few details I’m gonna try after watching your vid.
Can you tell me how you shifted the horizon in your camera? Is it a MAX 6 thing? I’m still on 5.1 because of the lack of DR…
Thats a very good tutorial. Really helped me! Thx for that tut.
Broken link :?
its broken because of bandwidth problems … hold tight
