rose colored glass help
Client wants to see rose colored glass like in the photo - and I can not get the same results - can anyone give me some pointers on how to get this effect in my glass?
CDI3D
www.cdi3d.com/files/rose.jpg
id just adjust the reflect color until it looked about right. Or adjust it in post.
Percy - thanks for the reply - what is the easiest way to isolate the glass for post
well you can render out a mask pass, make the glass white and everything else black. you can also render out a reflection render element. Or you can render out a vray wirecolor render element. All would work just fine. Heck you could even set the glass to -1.0 alpha contribute in its vray properties. Itll show up in the rgb render but have no alpha. Then just select the glass through its alpha. No need to render out a separate mask/reflection pass in that case.
I usually give the objects that i want masked out a pure white self-illuminated material, while assigning a pure black to everything else.
