rotate coronasun ?
hallo,
i’m new to corona but i love it already.
at the moment i made a house and placed a coronasun for the light
the problem is i would like to rotate the sun so it shines from a different place and i cant find this parameter.
where can i find this or is this impossible ?
if this is impossible what can i do instead?
thank you for reading this and i hope someone can help me
See this:
https://coronarenderer.freshdesk.com/support/solutions/articles/5000516719-how-to-add-daylight-to-my-scene-
Select the sun and find the rotation angle in their properties see image
You can also use Max’s native daylight system if you are used to it:
There will be no rendering time/quality difference.
thank you i will try this.
i tried editing the rotation of the sun but then my shadow dissappeared because it just stretched out the sun → shadow goes away over a big part
but i never used the coronasky because i always used an hdr
