Placed a HDRI material in environment reflection override… I wanna to rotate that hdri. I tried some offset setting but not seeing any movement. Any way to rotate Light HDRI material…?
Thanks.
Thanks.
Offset U for the rotation, 1 = 360°
If u rotate ur HDRI sky to 180° put 0.5 in Environnement overrides Offset U.
Exemple : 238° = 238/360 = 0.66111111111 Offset U
Etc.. !
Thanks, it works.
I was putting more values, was not knowing that 1 = 360
Thanks.
In 3ds Max we have rotation in degrees in the Corona Bitmap. I think it makes perfect sense to add it to C4D as well.
This is not in the Corona Bitmap. It’s in environment settings and the values are consistent with C4D.
Looking at it again, C4D has the “%” sign in the spinbox, so maybe we should add that too.
I am feeling better and better…!
