Metal ball, white diffuse. 0.0 Roughness
Box below, Frosted Glass material library preset
Corona light below the box.
When the metal ball has a roughness value of 0.0 then the reflections are correct. Anything higher and the frosted material almost disappears and the hotspot from the light is the only thing visible.
This doesnt happen with the corona physical frosted glass preset, only the legacy material.
Personally I think moving everything to Cosmos in general is a crime. Much prefer the UI of Corona Material Editor (although it is slow!), and importing from Cosmos always seems like a… fragile process at best.
There just isn’t the peoplepower to convert them, it would take much manual intervention and thus delay work on other things, so the solution is just to move them onto Cosmos as they are. After all, we wouldn’t be revisiting them in the CML to convert them to Physical either, even if not moving to Cosmos. Any time developing materials would be better spent making new ones, anyway
PS - the CML will still be there, initially like today as part of the install, but in the future as a separate manual download and install if you really want it.
Im curious, do you track CML useage as part of the useage stats? Is it a minority of users that actually use it frequently?
I use it every day for starter/base materials but increasingly find myself using the presets in the physical material.
Is there a way to allow users to create their own physical material presets?
Not something that we currently track. Feel free to let us know here of course as to how often you make use of it, like you just did!
Good to hear the Phys Mat presets are doing a good job of being the base starting point for things for you, definitely what we hoped for and intended.
There’s no plan at the moment to allow for the creation of your own Physical Material presets (but you know the drill with feature requests lol ). There is a plan to allow custom Cosmos assets, perhaps this year (so Corona 13 for us), which if plans and intentions over on the Cosmos dev side come to pass, will mean being able to add objects, materials, etc. of your own into Cosmos. We’d have to wait and see if that happens, and what it looks like / how it works when it does
Good to know thanks Tom! Ill definitely drop in a request for adding custom physical presets because it would be very useful to not have to deal with the max material libraries.
