RPC and vray 1.5
Has anyone used rpcs with vray 1.5 and the physical camera? Mine are not showing up - any ideas?
Most likely you’ll have to use a standard camera.
Thanks Vlado - That is what I have done - I just like the lighting I was getting with the physical camera - Will this work in the future?
It depends on what is the reason for it not to work. If it is because the V-Ray camera does not provide some information required by the RPCs, then we can fix it. But if it is because the RPCs are specifically expecting only a standard camera, then it would be for the guys at ArchVision to correct.
So the problem was in the physical camera; this is corrected for the next RC of V-Ray and RPCs seem to render fine now.
Great news…thanks very much!
