I have a problem saving files in .rpf format ,rendered with vray and max6,
when i import the fotage in combustion 3 , i cant view the separated objects…
I enable every channels in the gbuffer pannel..but noting ..
When i render with the standard Scanline, works fine..
Please help me.
vray does not support combustion at this moment. See this thread.
http://www.chaoticdimension.com/forums/phpBB2/viewtopic.php?t=5256&highlight
They say the 1.5 build will have render passes. Gadzooks
Here is a Vray rendered RPF in combustion.
Yest it works, but u cant’ select ( in ur example) only the Cilinder, or onli the box ..
U have the wole image …and not the separated objects..
Sorry, I misread the first post, you meant like this
I mean like this., image rendered with max scanline..
One rpf image, and i can select every single object..
CopyandPast this http://utenti.lycos.it/asd1/C3rpf.gif
oh that, yeah layers are not supported, but using G buffer extract gives the same result, just a bit more work. I wouldn’t say compositing with vray does not work…
