RT Bug with spotlights?
I’ve run into what may be a but with RT and Max spots.
When I turn off a spot during interactive rendering and then at some point later try to turn it back on, it won’t render.
I have to close the active shade window and start a new one to get the spots to effect the scene again.
Anyone else seen this?
Was it the only light in the scene?
No.
2 Max spots.
5 Vraylights (spherical)
1 Vray sun (off)
If it is a reproducible effect, would it be possible to take a look at the scene (you can send it to vlado@chaosgroup.com)?
Vlado,
It is reproducible. I’ve now seen it happen on a second scene.
I turn a spot light off and then turn it back on. The light will flash briefly (for a split second) in the scene and then have no effect. I have to close the window and restart an ActiveShade window to see the light again.
I am mailing you the scene.
Thanks for the scene; I can reproduce this here and I’ll let you know when it’s fixed.
