I’m still playing with demo but I’m not able to run DR with two remote render servers
It works fine with 1 local server + 1 remote server
It works fine with 1 remote server but not more than 1
From the help file “DR is limited to two render servers - these can be either a local render server and one additional machine, or two remote render servers”
Maybe I’m missing some fundamental step?
I’m on xp64 with max 2009
server are xp32/vista 32
vray sp3a
1 remote server + auto start local slave CHECKED= 2+4 buckets
1 remote server + auto start local slave UNCHECKED = 2 buckets
2 remote server + auto start local slave UNCHECKED = 2 buckets (overlay warning DEMO limit) - my understanding is that this should work!!!
2 remote server + auto start local slave CHECKED= 2+4 buckets (overlay warning DEMO limit)
Each remote server works fine as far as it remains alone
local is quad running xp64
remote are dual running xp32
I can add that each server could respond efficiently only using IP instead of computername
Hm, V-Ray RT doesn’t use buckets (at least not in the same way as the normal V-Ray and you won’t be able to see them), so maybe I don’t quite understand what’s going on?
I’m sorry for my messy infos, I’ve written buckets instead of cores.
I’ve 1 workstation quad core and 2 remote server dual core available; I’ve understood that RT could work different from standard DR, in particular it seems to me that it could leave the workstation free (excluded from DR), is that correct?
So I was simply trying to test it but the following are my results:
1 remote server + auto start local slave CHECKED = 2+4 cores
1 remote server + auto start local slave UNCHECKED = 2 cores
2 remote server + auto start local slave UNCHECKED = 2 cores (overlay warning DEMO limit) - my understanding is that this should work!!!
2 remote server + auto start local slave CHECKED = 2+4 cores (overlay warning DEMO limit) - that’s correct because it exceeds the demo limits
When I’m talkin to cores I’m referencing to what I see from task manager.
