RT Issue CUDA error 2 : unable to allocate enough memory to perform the requested operation (out-of-mem)
For some reason I am not able to post this in the RT section of the forum.
This is the full error that I get: ./src/ocl_tracedevice.cpp(4047) : CUDA error 2 : unable to allocate enough memory to perform the requested operation (out-of-mem)
I understand that it seems like the GPU is out of memory. In order for me to adjust my scene, I need to know how far over the memory limit I am. Is there any way to see how big the memory requirements are?
I am running an 8gb GTX 1080. Note that renders do work when I render simple scenes, so I know RT is working.
I see here that hair is 4.6 gbs worth of space. What is the “hair” in scenes?
Mtls 439.81MB, Geo 912.92MB, Lights 16.03MB, LightCache 0.00MB, Hair 4655.97MB, Other 261.92MB (data index 467891)
Building optimized CUDA kernel (0) for comp cap 6.1 for device 0…
PTX file generated with CUDA Toolkit v7.5 for CUDA compute capability 2.0
Optimized CUDA kernel assembled successfully
Total memory for device 0 : 8192 MB, free 38 MB
Device 0 statistics:
GPU time: 0.619208 %
GPU ray trace time -1.#IND00 %
Transfer to GPU time -1.#IND00 %
Transfer from GPU time -1.#IND00 %
Closing RTEngine (cancelled)
Hair stands for “hair” and “fur” and all of the similiar other “non-geometry” objects that are “hair” - like.
Best,
Blago.
So this could refer to proxy trees like from laubwerk?
I assume the issue occurs only when trying to render a particular scene?
Could you please pack the scene (Extensions > V-Ray > Export > Pack Project) and send it over at support@chaosgroup.com for investigation (might want to use a file-sharing service of your choice).
My colleagues will be able to identify what exactly is eating up all the video memory and offer advice how to better optimize your scene.
Kind regards,
Peter
