How do I setup the RT Render Server as a registered service so I don’t have to start it up manually each time ? When I do this with the supplied link I, the RT ActiveShade window hangs at “loading image data”, and there is an error when I start up the RT Render server manually (on top of the registered one): can not open listening port ( 10048 ).
When I don’t have the Render Server registered, and start it up manually, everything’s OK.
This error ( 10048 ) means that there is another copy of vray.exe already running in server mode.
On your local machine, there is no need to register the render server as a Windows services - the RT client in 3ds Max will start it automatically.
If you do want to register it as a service anyways, make sure you use a regular user login for the servrice to run with (right-click the service, choose “Properties”, “Log On” tab, check the “This account” option and enter proper user name and password for the machine). This is because, by default, the service runs with a system account, and this prevents it from communicating with the 3ds Max render client on the same machine.
Note that you only need to do this on your workstation, there is no need to do this for a dedicated render server machine.
Ok then; make sure you set the properties of the service so that it runs with a regular user login on the system; otherwise the 3ds Max RT plugin and the render server will not be able to exchange data because of different security rights.
Check if there is another instance of vray.exe already running in the Task Manager (don’t forget to turn on “Show processes from all users”); if there is, then the render server is already started.
did check, have only one vray running and i’m not running the server manualy. RT supposed to launch the local one automatically no? and still i get the disconnect error + black screen
If you registered the V-Ray RT render server, unregister it, and leave the “Auto-start local slave” option on in the V-Ray RT settings. Just in case, clear any render servers listed in the dialog. Then start the ActiveShade to see if the local server is launched automatically. If there are still problems, please email me to vlado@chaosgroup.com and we’ll try to solve them.
I set up RT fine on my host machine and erything is perfect. I ran the setup on two other machines as standalone render slaves and then point the serveer to the correct port and location to my machine. Then I click the V-Ray RT render server to run it. In the dos prompt I get a message saying “System cannot execute specified program”. And then shows me the path in which the program is installed; “C:\Program Files\Chaos Group\V-Ray\RT for 3ds Max 2010 for x86\bin”. Can you tell me what is wrong with this? My IT guy was here for an hour trying to figure it out.
Do you have 3ds Max 2010 installed on those machines? If not, you may have to install the Microsoft Visual Studio 2008 SP1 runtime (available from http://msdn.microsoft.com). Alternatively, you can email me to vlado@chaosgroup.com for a V-Ray RT installer that includes the correct Visual Studio runtime also.
I had the same problem.
Right click on “My Computer” goto “Manage”. Click through to see your services.
make sure that the service “VRayRTSpawner” has not started.
Mine was set to automatic and was running. Same error when rendering locally.
Right click it. Stop it then set it to manual - Not automatic.
