RT VP Scaling
I am trying to use RT in hybrid mode. All is good, but the VFB scaling is on, so it’s scaling to the size of the VP. I go back and uncheck it, come back to RT and it still scales. When I go back again that check is back on.
I’m not able to replicate that here, is that 3.60.03?
What about 3dsMax version?
Are you able to replicate it always without any special actions or it appears randomly?
I was trying to use RT with IPR. Without IPR everything works as expected.
It’s a bug… will make a note to fix it. Thanks for the pointer!
IPR Adv and RT have different “Fit to VFB” options. The IPR one is in Settings/IPR options and the RT one is in the V-Ray RT rollout. Are you sure you’ve disabled the right one ?
