Max 2010sp1, vray sp4+RT sp1
If I select body object in max and than go to the FACE subobject level and try to adjust face display parameters (all this while RT is active), this will crash max to the desktop instantly and every time.
This used to work ok with previous version of RT.
Anyone else experienced this?
Thanks!
vlado
November 5, 2009, 12:25pm
2
Can you get me a scene for this to vlado@chaosgroup.com ?
vlado
November 5, 2009, 2:08pm
4
Thanks for the file; can you tell me where I can find the body_object.dlo plugin?
Body object import dlo comes with Connection extension from Autodesk. It allows us to import rhino nurb surfaces and objects via SAT export/import.
That is what the geometry in that file is: nurb surfaces from rhino imported with acis sat import plugin.
vlado
November 5, 2009, 2:41pm
6
Yep, thank you; will try to get it.
vlado
November 5, 2009, 3:47pm
7
For me, 3ds Max hangs when I try to adjust the face display parameters even without the V-Ray RT plugin loaded at all.
