rtt saves only black images
hi vlado
i get only black images saved out of rtt.
tried jpg,tga,png,bmp…
have to save them all manually.
thomes
btw…dr doesn´t support rtt ?
Do you use the 3dsmax VFB or the V-Ray VFB?
max
Then you can try to use the V-Ray VFB with the “Split render channels” option and see if it helps. I will be looking at the issue though.
Please make sure “Don’t render final image” isn’t ticked. It’s happened to me before, makes you feel real silly. :wink:
