Rugs and Carpets
Hi Guys,
as there is no Corona FUR at the moment and C4D Hair is only supported if you convert it to polygons I was wondering a good way to approach long hairy rugs?
Like for example this one:
Thanks!
Well, there is hair planned in the core, but for now, I suggest using Cinema hair and converting it to polygons as you said yourself.
Just as a reminder: You don’t have to convert your hair object to polygons to make it work with Corona, generating polygon hairs in the hair object does do the trick, too. So you can keep your hair parametric. Does not help with the amount of polys, of course.
