Runtime error Windows 7 64 bit
Hi Everyone,
I am getting runtime errors
“This application has requested the runtime to terminate in an unusual way.”
This only happens when using very high resolution textures.
Rhino V4 SR 6
Vray 1.05 (?)
Has anyone encountered this?
Re: Runtime error Windows 7 64 bit
Hi Alrami,
thank you for your input. These are models, textures and angles that previously worked. The only difference is that I moved from XP Pro 32 bit, to Windows 7 64 bit. The models render fine with Vray materials, materials I make, just not some images applied as textures. Like I said, the frustrating thing is that the exact same materials worked fine in XP.
Hi Alrami,
thank you for taking the time to respond to this. It is the textures.
Apparently Windows 7 64 bit is not good to high res jpegs. I tried downloading some new ones with the same result.
In the mean time I have found a work around. I open the image in Photoshop CS4 and simply save it with a new name and max quality. So far all images I have tried this with work.
Thanks again.
p.s. Strange though that no other programs have issues with the “corrupted” images. They open just fine in CS4, Paint, Word, and Powerpoint.
I use Win7 x64 in my bootcamp Mac Pro, so far no problems handling large texture and big scene renderings. tri to fix the images in PS. and put them on by one in your materials.
