Safe frame dimension / image aspect ratio in camera setting
I was wondering if it would be possible to set the safe frame and the image aspect ratio in your camera settings.
Currently i have a scene with about 10 cams in it with different setups for the image aspect ratio.
When swithcing between camera’s it would be nice if the viewport would update the safe frame according to the image aspect ratio that is defined for that specific camera.
Best Regards,
Joost
This would be very helpfull, but if it’s not possible for vray then use the batchrenderer.
