when the texsly is 0.5
and the Gi is 2
does it mean that together the sun intensity is 1?
Uploaded with ImageShack.us
and the Gi is 2
Re: same parameter?
I’m curious myself, did you test it? I generally just use the intensity value and keep the GI and BG values 1.0 or less.
Re: same parameter?
the spinbox that is next to a map button controls the over all multiplier for the texture, not just one parameter in the texture.
Re: same parameter?
I don’t think so. It feels like if GI number controls the global light dome around the model, increased number would produce an overall lighter image. Sun intensity changes the brightness of the actual Sun, of the actual spot in your environment the represents sun.
It’s kinda hard to explain so sorry if I wasn’t clear ![]()
