Same render speed on different hardware in netrendering
Hi, I don’t know if is a Bug but in net redering huge resolution Images (4500x4500px) all three computes process a similar number of passes.
The main is s I7-960 and the slaves are a i7-4930k and a 4770k.
In normal resolution images the number of passes are proporcional to the each computer speed.
Thank you.
Does this also happen when you render normally on the machines? Can you run the corona benchmark (Corona Alpha4 Benchmark scene - Corona for 3ds Max :: General - Chaos Forum) on all slave machines and post results?
