I have a Scene with multible objects and several Material IDs. I’m using the IDs to generate multimatts in the Render-Elements.
But now I want to make an additional layer with all Material IDs in one Image.
I thought the “Surface Material ID” Output from the Sampler Info should do the job: (samplerInfo.vrayMtlIDTex)
I tried pluging it into a ExtraTex or straight into a Material Input but I can’t get any Results.
The MaterialIDs and MultimatteIDs are defined in the Vray Material on the Object:
Is there anything I’m doing wrong or is this a Bug?
You can just add a materialID render element, but it will contain the “materialID” portion of the vrayAttributes from the shader, not the multiMatteID.
We have a new render element called “multiMatteID” that will do exactly what you’re after and it’s already in the nightlies and it will be included in the next SP.
As a workaround, you can add your objects to a single vrayObjectProperties and override their objectID, then use an objectID render element.
You can combine that with render layers and render layer overrides.
Thats great. I hope we finde the time to update our machines soon.
[/QUOTE]As a workaround, you can add your objects to a single vrayObjectProperties and override their objectID, then use an objectID render element.
You can combine that with render layers and render layer overrides.[quote=“Vizioen, post:2, topic:49691, username:Vizioen”]
Good idea but thats not quite what I was going for. I still want to have the value of the actual ID. Since I’m rendering exr’s it’s no problem to use values higher than 1 or even negatives. So I could have all ID’s without limitations in on Pass.
I will just use the normal multimatt Render Element for the moment till we installed a newer Version.
The materialID would work but I don’t like to use it since I can’t see what value I used without clicking on the color.
I could connect the MultimatteID with the MaterialID. But thats something I would need to do for every shader and since the hole idea was an More effecient workflow without extra effort thats not what I want.
I wil use multible passes just like I did till now.
Great to know that you added this feature and I’m looking forward to test it.
