the sampler info node is not working in version 11193 Maya 2009 X64.
Greetings Paul
Greetings Paul
Thank you finding out this so quickly. I’ve broken it a couple of days ago while trying to support some more complex shading networks. I’ll write back here with some more info later.
Greetings,
Vladimir Nedev
i hope it didn’t break because of my request for the mapable place2dTextures attributes ![]()
Not exactly, but pretty close
I had a scene from another user for the same issue, with a shading network that connects the input attributes of a place2dtexture node to a shading switch (which then has its output to another place2dtexture). The sampler info broke because I tried to make that shading network work. Still, my mistake.
Greetings,
Vladimir Nedev
Quick question, is the problem fixed in the latest release?
Greetings Paul
Yep, it is, I fixed it on Friday, actually. Sorry, for not writing here.
Greetings,
Vladimir Nedev
np, thanks a lot. I´ll try the new version asap.
By the way, the latest build works with all the samplerInfo attributes, I’ve added support for the uvCoord, uTangent, vTangent, pixelCenter and rayDirection. You can test them out if you find them useful for writing shaders.
Greetings,
Vladimir Nedev
Great !
Thank you.
