hi friends ![]()
anyone some ideas how to make sandwaves like this?
for using as displacement?
i’ve tried with ps,but my results are bad ![]()
thanks
http://fizyka.phys.put.poznan.pl/~pieransk/Physics%20Around%20Us/Sand%20waves%2010.jpg
hi friends ![]()
thanks
I did something kind of similar I guess, but it was for a wall pattern. You need to use the pen tool & paths in Photoshop so you can make the curves nice & smooth. Here is the displacement map I made and what a render of it looks like.
@timmatron…thanks fot the tip,but how can i draw the paths with the pen in ps??
@cubiclegangster..thanks,i will try it out!
It basically works similar to how you create spines in Max. Using the pen tool, you select points and create lines and curves with it. Then you can adjust those points with bezier handles. When you get a shape you are happy with, you can stroke a brush along the path to create the actual layer that you can then start as a base for your displacement map.
many thanks for your help!
No problem. Looking forward to seeing what you do with it.
i was totally going to steal that displacement map until I looked who posted it ![]()
What now that you know I did it, it’s suddenly not good enough for you??? ![]()
lol no, ill just see if I can find it on the maps drive ![]()
cubiclegangster: Great link. I have never seen this software before. Nice post.
timmatron: That’s a really nice displacement map. And thanks for the tip on how to create such maps in photoshop.
