As in attachment, when I add just a little saturation there are problems in color. The background is a place with just a gray color from Corona. All light are white and nothing pink in scene! what happen?
And also without add saturation the image appair so low in saturation…
I use last Corona
Thank you Juraj! I understand! Yes it’s true, I see that Tonemapping is extremaly sentitive..
I notice it now because I dont remember on previous versions of Corona have seen such problems on the color… I will try to reinstall previous versions to verifiy it.
Ok, great, thanks for the explanation. But can you please render this in the VFB with default saturation, right click on any of those gray pixels, and check their RGB values? (right-clicking should up a color picker with various information printed in it)
I am asking, because some time ago a similar issue was fixed, so this is definitely not expected.
Yes! as you can see in my attachment, I rendered a frame with a default value in the saturation, and all is ok, but the problem happen when I increase the saturation and the grey color change in pink this is strange…
However, rather than just the screen grab here, we really would like to know the RGB values of one of those grey pixels in the VFB, to see if they are truly grey, or if there is a slight color tint to them. If you could do as Marcin suggests, and right click in the VFB to bring up the pixel information, and screen grab that, it would be a big help. Thanks!
Standard Max Color Correction (in “advanced” mode) or just options in the Output rollout of bitmap nodes and standalone Output map (color map preferably). We abandoned “Color Correct” some time ago after decades because I thought we would not need it any more - maybe I was wrong
Ok, so the tone-mapped values are:
R: 208
G: 206
B: 207
That’s why this color becomes pinkish/reddish when saturated. The question is: why are they like this if the original values are identical. Maybe it’s environment lighting, direct light, indirect light, or color temperature?
