"Save all" multi pass bug ?
“Save all” does not provide for proper multipass images. See attachment. Left is the saved by “copy” to clipboard and right the saved by “saving all”.
Alpha channel “save all” by a greyish image. Copy to clipboard works well.
The copy feature in the VFB is actually very handy since I can open the copied images directly in Preview on a Mac. It’s also much faster it seems.
I also attached a low res Beauty pass unprocessed straight from Corona.
14 update 1 has few problems for me other than the above and the occasional black lines.
Mac Studio m1 128Gb OSX 26.1
CR 14 update 1
C4D 26.1.0
It is expected that the cryptomatte pass you see in the VFB is just a preview, it doesn’t serve any other purpose and does not provide usable data. Once you save as CXR, rename to EXR, and open it in software that can process cryptomatte data correctly, you will get usable results.
Please see: https://support.chaos.com/hc/en-us/articles/4954345529489-How-to-use-the-Corona-Cryptomatte-C4D
Thanks Marcin,
I will look in to that. I was using the cryptomatte’s as a different form of material ID. But of course it has much more functionality I was not aware of.
Anyhow, the black lines issue is now much worse. Basically saving renders can only be done by copying to the clipboard. Very occasionally I get a render saved normally without the lines.
Here is the latest one. Only a few lines.
CR 14 update 1
C4D 26.1.0
We are looking into the black lines issue with top priority, it’s critical.
