Please add the ability to save archicad view within enscape
The synchronization of views from Archicad works very well, it is enough to set up cameras in Archicad.
It would be more useful to automatically save settings with the project and import animations directly from Archicad … although this can also be done manually ![]()
Hey @arcomer , this has already been requested before so it’s on our agenda.
I’ve added a further upvote through your voice to the topic, thanks a lot!
@Tikos , settings saved with the corresponding project is on our agenda, filed as a feature request so I’ve given the topic a further upvote through you as well. Further, the ability to import animations directly from ArchiCAD, shall I file this as a dedicated request? ![]()
Would be nice ![]()
In spite of everything, I think that setting the animation path directly in Archicad is simpler than in Enscape, although the animation can also be moved very quickly manually with the help of view synchronization and adding key frames. Well, you can set several paths in Archicad without having to save each one in a separate file.
Sure, thanks a lot for getting back to me!
I’ll file it as a feature request accordingly. ![]()
Also wishing there was a way to go from ArchiCAD’s saved views to Enscape and have it reset the camera angle etc.
I’m trying to keep a series of 8 views and render their progress through the life of the project. So I need to get the SAME angle, sun angle and other environment settings to produce these 8 renderings.
I am now having to render 1… the shut down the ENSCAPE window, reset AC’s 3d window to view 2, reopen up Enscape and render and repeat x No. of views.
It would then be a BONUS if I could actually PUBLISH these (somehow) from ArchiCAD’s publisher…
I wouldn’t be bad if Enscape could have it’s OWN saved views (with all the settings remembered)…
I don’t actually NEED to structure the views in ArchiCAD… just seems like the only way to do it now.
Hey @DGD-Duane , thanks a lot for your feedback.
I’ll happily add a further upvote through your voice to the corresponding topic to have views in ArchiCAD as well. ![]()
