The only save I can do from the VFB is with the save CXR. If I want to just save a quick jpeg just by clicking on the save button once, nothing happens. It is the same with 1.6 HF1, HF2. It use to work??
Hi and sorry for a delayed reply.
Is this still happening, or did you find a solution somehow? If it’s still there, can you explain what exactly is happening, or even better, record a video, or share a couple of screenshots showing this?
Hi, No problem. Not sure what changed? It isn’t happening anymore but if it does I will make a video for sure.
Thanks!
I am having the same issue. Using Corona 1.7 (hotfix3). Is there something that can be done to solve this problem?
Just found a solution.
Delete ENU folder from the following location:
C:\Users\Username\AppData\Local\Autodesk\3dsMax\201x - 64bit
Make sure you create a backup before.
Best
Hmm… this sounds like some random issue in 3ds Max then. Great if it works. Thanks for sharing the solution.
Welcome! Thanks for replying!
