save file question
Hi, i have doing a animation recently, may i know can i save (vray raw image file) with denoiser in EXR format, and the same time can i use the (seperate render channel) save to save other render passes like vraylight, vrayreflection in TARGA format?
The only way i know how and the way we do it here is with a postrenderframe callback script. check the docs here:
You can set the regular 3ds Max output as JPG file, and enable the raw VFB output to write a vrimg or a multichannel OpenEXR file.
Unfortunately that method doesn’t give you all the passes just the RGB colour.
