Hi
I just upgraded to Max2018 and find when network rendering that I have to save the file name/parameters twice (or else elements aren’t saved), mainly due to the (new) save file action just under the render button in render setup, can this be switched off ? I tried ‘ignoring’ it and Max then informed me I am rendering and not saving the files and they weren’t saved, wasn’t like this in Max 2016 ?
cheers
John
I suggest using the ‘V-Ray raw image file’ and/or ‘Separate render channels’ saving methods, located in the Frame Buffer rollout of the render settings instead. If you are rendering sequences, you would still get the ‘No files saved’ message, however, the output will be saved.
Hi
‘No files saved’ message was confusing me, thanks
