Hi guys, how can i save images with 32bit?
Have you noted that rendered images have some colors waves??? how do i minimize it or how do i stop it???
I think is because wen we save a image it is 24bit, isn’t it?
Re: Save imagens 32bit
The only way is to ouput the render in VRIMG then convert it to EXR (look for the tol on the download section ).
Tom, thats incorrect.
V-ray always calculates full floating point (ie 32bit) data for every render. If you want to retain that data, then you will need to save using a format that can support 32 bit color information. Right now we support 2 formats that do, EXR and HDR. Both formats are available to save directly out of the frame buffer.
dalomar thanks, and can u answer my second question??
“Have you noted that rendered images have some colors waves??? how do i minimize it or how do i stop it???”
np Tom…just wanted to set the record straight.
I have seen these waves before, but only when a monitor had its color quality set to medium (16bits)…the solution is just to open up your appearance settings and make sure its set to High (32bits).
It could also be due to monitors which has 16.2M colours instead of 16.7 On the lower end monitors they often cheat to achieve a low refresh rate.
