hello
is there a way to save LC & IR maps automatically if render hit?
a script or something else?
would be great if it would save the maps with the name of the imagefile and add _LC or _IR to the filename and save the files into the same folder.
best regards
themaxxer
Not sure I undestand the whole question. What do you mean if render hit?
As I’m sure you’re aware, you can autosave them, and I think since 1.5, the lighting passes are saved prior to the rendering pass.
sorry, my english is not the best.
I mean if it could save a LC & IR map when pushing the render button, without to save it manually each time I want to render another view.
for example I want to render ‘cam1’ then it saves a pass ‘cam1_LC’ and cam1_IR’ into the same folder where the image is saved to.
best regards
themaxxer
Oh, I see. So it would be automated such that you wouldn’t have to specify the file save and name each time. Yes, that would be helpful.
