Save Rhino file while rendering in Progressive mode
with V-Ray 3.40.03.
If you save the Rhino/SketchUp file while rendering in Progressive mode, rendering will restart.
(Auto backup will cause problems)
There is no problem in bucket mode.
Please improve the Progressive mode.
This has already been logged and resolved. The solution will be available in the upcoming v3.6.
Thank for you bringing this up, nevertheless!
Kind regards,
Peter
Thank you.
Wait for updates
It was confirmed that this problem was reproduced with V-Ray Next SketchUp HotFix 1 (4.00.02).
Will the issue be fixed in the next update (4.20)?
I confirmed that the problem was reproduced even with 4.10.01 (update1).
Please correct it.
Thank you for your report! A ticket is logged and its priority raised. Will post here once the dev team has devised a solution (earliest implementation would be the upcoming v4.10.02 minor update).
Kind regards,
Peter
