Save separate channels small issue
When you change the target name in the “split render channels” in VFB, it doesn’t recall the already typed name, and you have to retype it entierly if you only want to increment it (for example)
I had also to re-choose the extension format & parameters.
It’s quite annoying, and I had the issue yesterday while rendering over backburner, I misclicked somewhere and it lost the UNC path to replace it by a D:/… The slave had no D:/ and I lost the rendering :frowning:
Hm, in the UI you can’t type a value directly, you always have to use the Browse button for the “Save separate render channels” option. How did you manage to type the name directly?
I guess it’s the issue that the in the “split render channels” dialog the path and filename information gets lost every time you click it… means if you already have a save output and you go to the dialog again, it is not pointing to the path and filename that is already set.
Was also quite annoying to me already.
So second that one :wink:
Michael
Yes, Micheal is right. I’m not typing directly, it’s when I click on the browse button that the path disappear and I have to retype, or rechoose it every time. That may lead to small mistakes like losing your UNC path to a local one (when you’re tired and you doesn’t pay attention ;))
