Hello!!! I have an heavy scene, with a lot of items from Chaos cosmos (cars, characters, etc), and when I want to save all internally (save with assets), the program ask for every item from Chaos… is there a way to save easily?? thank you for help!!!
sorry, not Chaos, Cosmos browser… but it doesn’t change, it’s a pain to save internally!!
Hi there @celmar
Could you please share a screenshot of the issue?
If C4D can find all assets that are being used in the scene project, then using the “Save project with Assets” tool should be pretty streamlined.
If, for any reason, C4D is not able to find an asset, then it will ask for a folder path for each asset that is not available/reachable in order to retrieve them.
The whole file handling is managed entirely by C4D.
I hope this helps.
Looking forward to hearing from you.
maybe try to set the path where cosmos saves the data to your c4d preferences/file paths
