Saveable Vray VFB Region Render coordinates
Just a quick thought for wishlist item - the ability to save a vray VFB region render area as a named preset. This would make it easy to set up regions for different parts of the image (if doing stills) depending on what you
are working on without having to do a quick render of the entire shot just to be able to select the proper region. I know I could use the max region render to select it in the viewport but that can sometime be a headache.
