Saves rgba image ?
One object render with object buffer mask, when saves… its with rgba file also…!
When remove mask… it doe not saves rgba file.
Any idea…?
Thanks.
Hi there.
Could you please elaborate a little bit more about what the issue is?
Thanks in advance.
Kind regards
I believe you still need to tick the Alpha channel box. At least I always do.
