Hi!
I´ve noticed that vray wont let u save an output from 3dsmax save dialog and, at the same time, from vray frame buffer section “Save separate elements”. I would like to get a RPF with some channels inside it (NodeID, Zbuffer) and, at the same time, reflection, refraction, global illumination, etc layers. I cant figure out the way to do that in one pass, as the RGB-color element u are getting from Vray frame buffer output has no elements embedded.
Any ideas?
Thanks! ![]()
