If I save out the diffuse as say a targa, then go and save the wire channel, vray doesn’t remember the path that I saved the first image too. It’s sort of a drag - also it doesn’t remember the type of file you tried to save out the first time.
Is it possible (or for that matter, something that other people would want!) to have vray remember the path each time you save out a different element of the VFB?
This is if you’re just doing a render locally obviously.
Regards,
