Hey guys,
I noticed that doin “save all” from the vfb saves multiple passes in separate images. Is it possible to save all passes as layers in a single psd/tiff file?
From the C4d picture viewer you can select psd/tiff or whatever, then tick the ‘layers’ tick box. That should do it.
Yep I know this workaround already, you can save in a single file too if you set multipass save path in the render settings.
It would be great to have all passes packed in a single file doing “save all” from the corona vfb. Nothing special actually, just a feature that would be cool imho.
