Hi, I cannot find how to save the composition as a video.
I’ve got two layers and I wish to save out the result as mp4 is it possible or i need to pass throw other softwares ? For now i can save only one complete layer or the other.
File > Save Mask as sequence… will save the resulting composition (this is used both for saving to image sequences and to video).
Make sure to change the resolution mask as needed so everything fits in the mask.
You can change the mask resolution by right clicking here:
If you don’t see the info bar, you can toggle it from View > Information Bar (hotkey is `)
And you can view the mask borders by clicking this icon:
Hope that helps.
Hi, This helps but if i put the same resolution of the video in the mask it crop the sequence or it resize the video smaller.
Do i need no manually place the mask with pan and zoom or is there a way to simply render out the composition at the same resolution of the video input ?
This workflow is really strange to me.
Hi, I end up zoomming manually to fit the resolution, it is not perfect and a waste of time. Also every time I accidentally move\zoom in the view i need to redo it.
I was just testing the software to understand if it can be usefull for quick compositon, if this is the workflow is not.
Thank for the support
