Hi as far as tested on my end everything works. I created a test scene in 3ds max with background layer and saved and it worked. Also tested your EXR and it works in Nuke?
Hi I did further testing. In my initial test it did work now it does not.
After this confusion I proceeded and was able to confirm that if you load the background image after rendering it does not work but if you load the background image before rendering, render with it and save, criptomatte works.
Let me investigate a bit further and I will get back to you.
That’s right. After loading the Background, it will not be rendered again.
It was good to be able to reproduce the problem. Wait for the investigation.
