A couple of months ago I started saving my render outputs to 32bit and no exposure settings (burn/exposure/contrast) so I could get linear files to edit with ArionFX before saving them down to 16bit for the rest of the post work (adding people and stuff). However I have found that when doing revisions of parts of the image it’s quite a pain in the @$$ to get the 16bit versions to have the same lighting/toning settings. I don’t write down the exact ArionFX settings per image but try to stick to the same ones as much as possible, but even so they often come out differently.
So I was wondering if it’s possible to setup a vray backburner render to save both the 16bit with exposure settings and 32bit without exposure settings from the same render? Manually it’s easy as you just resave with the settings you want. Maybe saving as a vrimage file and opening that again in the framebuffer and then saving again will work…
