Sorry… but I’m quite new to Archicad - but how do I scale the assets from Enscape asset browser?
Hi @Brandt
You have to right-click the asset and select “Convert Selection to Morph”.
Afterwards you can use the resize function of ArchiCAD by adjusting the percentage value in order to keep the proportions.
Hello
Unfortunately, but transforming the object into a shape results in the loss of connection with Enscape.
Is it not possible to do scaling in a simple way in the next release?
greetings
Tikos
welcome back
Is there any information about scaling?
@Tikos I’m not aware of an issue regarding the live sync of Enscape.
We’ll check the feasibility for a easier solution but it’s currently the only possible solution in ArchiCAD.
My point is that if you convert an object into a shape in Archicad (ctrl + shift + F) then it also appears in Enscape as such a shape / solid (loses a proxy connection).
Also, the standard object scaling in Archicad (ctrl + K) is not possible / does not change anything.
Also, it is impossible to change its size “numerically” in the object settings window.
I do not have more ideas ![]()
@Tikos I can feel for you but we have to take whats feasible in ArchiCAD. So we’ll have to get in contact with them for further analysis.
Thanks for your testing!
Ok, so we’re waiting for a solution ![]()
Anything on this item yet? Would love to see Enscape Objects be scaleable in v2.6.
Not yet I’m afraid, but the topic has certainly not been forgotten on our agenda.
I’ll also add a further upvote to this feature request to allow scaling of Assets in ArchiCAD. Thanks a lot for your feedback.
+1
Added, thank you!
Ive tried Enscape 2.7 with archicad 22, but seems that there is no way to resize objects from Enscape asset library as we can do in Sketchup.
cheers
+1
I honestly cannot believe that Enscape can find a way to add animation to vegetation (v2.8 release) & not size/ scale abilities… ![]()
+1
I will make sure to up-vote the Feature Request for all those concerned here.
Any solution? Now with custom Assets it is very good to work with renders directly in the Archicad, but it is very necessary to be able to scale the blocks, especially those of vegetation.
I demand that you explain to us the reason why nothing is being done in this direction! The poor answers of your “specialists” are simply offensive. If your developers are so lazy to support users of archicad, just tell us that there will be no resizing of asset library elements!!
Hey @hoza ,
Welcome to the forums!
I’m sorry to hear you perceive our responses as offensive. This doesn’t have anything to do with our developers being lazy, it’s just that ArchiCAD doesn’t offer tools out of the box we could use to scale our assets, so the implementation work for this feature is very, very complex and something we didn’t have to do for any other CAD software, yet.
I have added your vote to the system, though. But to make it clear: at the moment, no resizing of asset library elements in ArchiCAD is planned.
Hope you have a great new Year!
