Hello, i’m having a slight issue with the corona convert proxies script. it doesn’t seem to work too well when converting vray proxies to corona proxies. once i hit convert, it does the converting but then the new corona proxy object gets so large in scale and fills up the entire scene then i have to delete cos i can barely zoom. i know this script wasn’t created by the corona team but i just wanted to know if any other user trying out corona has tried this script and got it work successfully.
The script wasn’t created by the Corona team, but it is shipped with the official installer, so we definitely take at least some responsibility for it, and we offer support for it. Which version of the script are you using? Is it the one included in the 1.4 installer?
Was the original Vray proxy scaled down? Maybe you need to reset xform of the original proxy before converting it? Or reset xform of the new proxy after the conversion?
Are we even talking about the one in the corona converter? There is also an old one flying around in the goodies section. The one from the converter should handle scaling properly - if not then it’s a bug ![]()
Actually, its the old one i came across. I"ll do as suggested and post back if any issues arise thanks.
