Scaled objects need modifications to VrayDisplacement Amount
I’m pretty sure I know the answer to this based off some tests, but I just want to double check.
If I have a sphere with a vraydispmod, and I scale the sphere to be 10 times the size, I also need to set the amount in the disp mod to 10 in order to get identical looking results, correct?
- Neil
What’s the equivalent of Maya’s “freeze transformations” on an object in Max? Reset Xform, I believe from memory? would that negate the need to adjust the displacement mod accordingly?
(in situations where you can use it, of course)
edited post because I hadn’t noticed it was Neil posing the question :stuck_out_tongue:
I don’t think it’s going to work; the displacement is currently always in world units.
Right, so if its in world units, then if I scale an object larger, I should scale the amount in the disp mod by the same value to get identical visual results, correct?
- Neil
This is correct, yes.
Cool, thanks!
- Neil
