ScalpelMAX
I am trying to create an animation like the image above where the slice goes from left to right cutting into the solid graph - exciting stuff :] . I tried doing it a number of ways using matts, sliding matts and morph - with no success. . Does anybody know of a way to do this ? - I am thinking that the only way to create it is with scapel from Cebas ?
http://www.cebas.com/products/products.php?UD=10-7888-33-788&PID=6
I’m not a big fan of Cebas has anybody used this plug in with Vray ?
Thanks as always for your help.
I have.
http://www.chaosgroup.com/forum/phpBB2/viewtopic.php?t=15912&highlight=dome
I liked it. Much better that using slice.
Just use a boolean, animate a box that is animated to slide over the graph and select it as the operand.
Boolean Eh ?
I hadn’t thought about that one - I’ll have to give it a shot - thanks for the fast feedback guys. I feel out the producer and see if feels like springing the plug-in it might come in handy for something else.
Thanks again - always a pleasure getting help from you guys.
Sweet
That worked like a Charm - animated Booleans ROCK !!!
Thanks again :]
Re: Sweet
can you show how it worked?
couldnt you just animate the slice modifier ? but i am glad you allready found a way to do this :wink:
Glad to help :slight_smile:
You could but the slice modifier won’t cap the end like the boolean does.
put an edit poly modifier on top of the slice and cap it :wink: thats what i did in my last project. but there are always several ways to accomplish a task in 3dsmax… :slight_smile:
Olli
I’ll post results and process on Tuesday
I’ll post results and process on Tuesday when I’m back in work - long weekend here in US.
nice :slight_smile:
The cuttting object needs to be animated prior to the boolean operation - there might be a way around this.
As another users suggested the slice and cap modifier method achieves the exact same results.
Hope this helps.
cheers for the pic, i can figure it out now :smile:
You don’t need to animate the operand first. If you choose the box as the operand then in the boolean display settings choose “Result+Hidden ops” you’ll then see the box next drill down to “operands” in the tree and you will be able to move and animate the operand as normal.
I knew there was a way to do it
I knew there had to be a way to animate after the Boolean :smile:
Thanks as always for the help.
I believe the boolean method would only work properly on simple geometry and the cebas plugin does work with more complex stuff. Dont know about the power booleans. :slight_smile:
