So I’ve come to rely on C4D’s Mograph Cloners, mainly for duplicating rows of cars in a line, grid or along a path. So simple to add randomness and amazing Effectors.
I know Scatter will be far better for grass, trees, rocks and other things I’m not aware of yet. Should I switch to Scatter to clone my cars? Is it more efficient and easier on the viewport? No effector FX?
Also, right now I usually have a hidden folder in my scene with let’s say 4 different car models and a copy of each one in several colors. I’ll make an Instance of each one and drag those into the Cloners. Easier to select and move around. As long as they are all set to Instance and not Render Instance or Multi-Instance since those options give me problems with Corona. Any advantage to using Corona Proxy instead?
Thanks for any insights.
