Conceptually difficult, as the displacement is calculated at rendertime (particularly for per-pixel edge lengths.).
The differences with the viewport would be potentially so big that the distribution, and number of instances, wouldn’t match at all, while calculating the whole displacement while not rendering could easily eat into a user’s RAM and/or kill a GPU trying to display the results (it’d work for smaller situations, not universally.).
The trick to use is to add a viewport-only max displacement (and a viewport only subdivide if that is needed) matching the v-ray displacement, and scatter on that. At rendertime there’d be at least some match with the V-Ray generated one (i think fPro shares the same limitations.).
I can understand that the workflow is not standard but now VrayDisplacement is everywhere and it is something that we can’t do without.
It’s a key feature for high end animation
Forest has integrated an effect section to make it possible
It doesn’t seems that munch complicated to me computationally once we have UV’s, displacement amount & shift and it looks like just a shift on a Z transform .
I see what they do: they don’t build the surface at all, just sample the texture.
I wasn’t aware of this at all, it’s indeed quite clever, you have definitely a point.
