Scatter edge trimming with texture baking
So I’m using Bake To Texture a lot lately, and I’ve just discovered a limitation on the scatter edge trimming;
I know this is a slightly odd use case, but let’s say I have some grass scattered on a landscape plane with edge trimming selected, it all works fine.
But when I use bake to texture on a flat 100% transparent surface hovering above the landscape the edge trimming isn’t applied and I can now see the ‘rough’ edges.
Any workarounds you can think of to force the trimming? Thanks
You can probably ignore this report. On closer inspection, multiple things seemed to have been going wrong to cause such an issue for me.
