Scatter + Multi Shader
Hi there,
I noticed a problem when I’m using scatter and multi shader for color change of the cloned objects.
When camera clipping is ON, colors of the objects are changing every single frame. I’v tested it with all Multi Shader modes.
Cheers!
Interesting. Would you be able to share this test scene as well?
My guess: Scatter does not scale the instances out of sight to 0, but actually deletes them. Therefore, the index of the instances is in constant motion and that is why as soon as it changes, the random color distribution changes.
I could only avoid the “jumping colors” by using a Cloner and an LOD object, because my “patented use the variation shader in Object name mode” even failed here :wink:
Please check this one.
Scatter+MultiShader.c4d (349 KB)
Just out of curiosity I’ve attached a Mograph solution. While it is working fine in the viewport, the “Use Camera Clip In Render” in the LOD object does not seem to work with Corona IR (no idea if in a final render it would have been used). Should I report this as a bug additionally?
PS
I put a mirror in the scene, it’s almost like a spy cam, hope I did not violate the privacy of the instances. The “clipped” objects are just rendered in the IR, in a final render they are gone.
mograph lod camera clipping cone.c4d (262 KB)
I’ve checked xParticles Scatter and Cycles 4D with Camera Clipping mode ON.
It has three Clone Types: instance, render instance and duplicate.
Instance and render instance work as in Corona Scatter (colors are changing).
Duplicate works good, but I think this mode is less efficient than instances.
I’ve tried xpScatter with Corona Render but with no luck - colors keep changing.
So maybe this is a path to consider while working on a solution.
Hi there, can you please let us know versions of Corona and C4D you are using?
(Internal ID=914121188)
Cinema R25 + Corona v8, MacOS
